WANTED!! POWER STEERING.
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: WANTED!! POWER STEERING.
    Posted: 17 Feb 2010 at 9:01pm
Looking for a charlynn power steering unit or a boylens unit. if there is anyone out there that has one and wich one is better. going to get it for my father he refuses to change the WD to wide front and the narrow is getting harder on him to turn but you know how the old timers are lol, NO OFFENCE TO ANY ONE OUT THERE> BUT YOUR STUBBORN> any help would be appreciated.
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 9:13pm
I have a charlynn power sterring unit off of a unstyled wc that I would sell.It will work for you but you may have to cut your hood to make the pump work with the brackets that are with the pump.Send a PM if Interested.
Thanks
Allis tractor puller CA WC WD D17
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 9:58pm
Why do you want you dad to put wide front end on the WD?  Wide fronts typically turn harder than a narrow front end. Maybe you should check the condition of the steering brakes.  lol  NO OFFENSE, BUT YOUR IGNORANT
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 7:15am
No point in being a butt about it firebrick43. You are the one that is ignorant. My wide front will turn as sharp as it did with the narrow front.  If you are not helping, shut up.
jjwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjwo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 7:58am
I have a whole WD with char-lynn on it my wife would like to get rid of. Only problem I am in Ohio. Transmission noisy. E-mail if any help. $900 for all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 9:14am
first of all to the other guy being a prick the wide fronts on all our tractors turn twice as easy as the narrow front tractors and we have a good collection of wd's and wd'45 and thanks to you others i will be PM'ing you guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 3:39pm
Joe, I didn't say anything at all on how sharp a tractor with a wide front turned compared to a narrow front end, I was talking about steering ease.
As to Kinghunter, My statement was in jest to your mocking statement posted first.  I did not call you names, as you did me, Ignorant means "not knowing" or "lack of information". Dont mock others if you cant take the heat.
All things being equal, Ie tire size and on decently hard ground, a narrow front end will turn easier.  My wide fronts actually take some steering effort to get started but my narrows can be steered completely with the steering brakes is so inclined.  I highly doubt that you wides steer twice as nice compare to your narrow unless something is very wrong mechanically.  Physically a wide front end has so much more friction do to the kingpins and many ball joints, all lacking in a narrow front end.
