GMC 302
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Topic: GMC 302
    Posted: 29 Dec 2013 at 8:01pm
 Can git a GMC 303 in line 6.... Will it bolt up to a WD.. Thout it would make a pulling motor.. it lugs down good..   4 in bore & 5 in stroke..   THANKS  FOR THE HELP...BOB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 12:29pm
they were a good old truck engine - lot of lugging power - also seen them used in stock care racing when reworked back in the old days when i raced turned up RPM and sounded like model airplane engine .
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 8:27pm
are you sure its 303? with a 4 by 5 bore/stroke it would be more than 300 cubes, my truck has a 3.98 by 4 stroke and is 300 cubes
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 10:51pm
It is 1955 GMC 302 in line 6 cyl..  Used in trucks...bus ..& miletary  trucks...  Do aney one know if it will bolt up to allis trans WD or WC.. its same patern as chevey....THANKS  BOB
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2013 at 6:47am
There is a guy on Youtube with one. Its definetly not a direct bolt up but it can be done.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
L Hud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L Hud Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2014 at 4:54pm
It is very doable. I did a 292. Adapter plate for the tranny and probably a spacer of flywheel. There are pics of mine somewhere on this board.    Hud
