5.9 Cummins in a 190
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 5.9 Cummins in a 190
    Posted: 29 Dec 2013 at 5:40pm
Friend has bought a 5.9 to put in his 190. Looking for info on an adapter/motor plate and any other tricks for it. Has the 301 in it now. Can the stock starter be used or use the cummins, Steel Flywheel, clutch setup, etc. That's the kind of info needed
Thanks, Larry
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2014 at 7:06am
bump
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2014 at 8:35pm
Look up Bob C from Ill on here he has some good advise .
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2014 at 11:34pm
If I had to guess. I would say bob is busy plowing snow. Im sure he'll get back to you eventually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2014 at 7:24pm
sounds good.   bet he is busy
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2014 at 2:16pm
Larry or Aclls are you guys goin to gordyville?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2014 at 2:22pm
no I am not. On call for the weekend at work
This page was generated in 0.186 seconds.
