AC Improvements
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: AC Improvements
    Posted: 16 Feb 2010 at 7:55pm
These grease fitting should have been installed on AC tractors from factory!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 8:03pm
you are right..especially on the hand clutch
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 8:16pm
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 2:19am
What you working on there Zyta?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 7:14am
Put a zerk on the steering support near the oil filter. A 90 degree on the block side will go unnoticed. If you have a wide front then the pivots need one each too. I didn't put any on the lift arm housing as I thought I wouldn't use the lift arms so much. I might add that some day but I might put 90 degree ones underneath to hide them. Too fussy I guess.
Wink
I am a Russian Bot
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 7:27am
Good Idea's! will look at that..what are we working on? last year I fitted and tested this 45 with a G262 Gleaner six cylinder. This winter I took her all apart to replace a bearing and gaskets using the Right Stuff gasket maker and looked after a few other adjustments. I love these old girls when they don't leak oil all over the floor. Tin work is all painted soon be ready to paint the drive train. I will post pictures once I get the 262 back in her in the next couple weeks.
