off color MM GUYS- Ground question
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: off color MM GUYS- Ground question
    Posted: 16 Feb 2010 at 3:21pm
I have a 1951 U LP and a 1955 MM U LP, where any of these U's positive ground.......what would happen if I tried it like that would it fry my electrical wiring?
As always many thanks
Anthony
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 3:52pm
Check the battery connectors and the battery posts. They are fat and thin for that reason to make it less convenient to connect the wrong polarity. Unfortunately if the cables or connectors have been replaced, all bets are off. You need to polarize the generator to the battery before starting the engine. Another check is the coil polarity should be the same as the battery, + to points for positive ground, + to ignition switch for negative ground. The coil polarity should match the battery polarity for the best ignition. An alternator and a solid state radio are absolutely unforgiving for reversed polarity. A solid state regulator too. A vibrator type regulator can be not too forgiving giving short life with the wrong polarity because of the different metals chosen for the points. Lights and starter don't care about polarity in the vintage tractor. A modern tractor with permanent magnet starter fields cares about polarity. The starter will run the wrong direction with the wrong polarity, but the bendix won't engage all the way probably.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 5:43pm
I have 4 U MM's and they are all Pos. ground. I belive that all MM tractors were Pos. ground  until the 60's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 7:19pm
If you hook the battery up wrong will it still spark at the points
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 7:49pm
   most all tractors up to the 60's were positive grd.  regardles of color
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 8:35pm
Thanks Norm, does that inlcude my Allis WD, it must have been change because ever since I bought it I have been running it with negative ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 8:36pm
it seems to run fine, just has some charging problems, my voltage regulator went out and I couldnt find another one to replace it, or maybe battery was hooked up wrong, what will your amp gage do if it is hooked up wrong will it show that it is charging
Roger A. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger A. NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 3:42pm
All tractors regardless of color WERE NOT POSITIVE GROUND. Case SC, DC and LA's were all negative ground from the factory.  V series and VA series were posotive ground from the factory
