545B engine problem
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Topic: 545B engine problem
    Posted: 17 Dec 2013 at 8:34pm
My boss has a 545B payloader and engine has been overhauled 2 yrs ago, now it starts great but when you wanna go push on the throttle(foot controlled) the engine just bogs down and quites.  This baffles me a little cause ive been around alliss all my life and dont really know where to start looking.  My 1st thought was fuel filter but ive never had that issue on any tractor before.  Thanks in advance for any input!!  Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2013 at 9:03pm
Does it have a "Simms" in-line injection pump???  might be a bad transfer pump which is bolted on the side of it.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2013 at 12:17am
On the FR 12 loader I had, the same as a 545 just a bit newer, I had a similar problem. I put an electric fuel lift pump on it and that seemed to solve the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2013 at 8:33pm
Dr dont know what you mean by "Simms"  but it has a Minnimec injector pump.  Eric it already has a electric pump on it.  Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2013 at 9:24pm
Check the filters then - make sure you have good flow as well as a good supply to injector pump.
Had problems like that on my H4D - filter plugged after short hours of use - bad fuel or ? Couple filter changes and no more problems.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2013 at 11:55am
might be a fuel gelling problem, I've seen it happen this time of year, acts just like that. how much #1 fuel is in the tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2013 at 8:50pm
No not a gelling problem as this started in the summer and we just parked it and used the other loader for feeding the cows!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2013 at 9:23pm
Thanks guys, after looking into it, it turns out it was the add on electric fuel pump so we replaced and the 2 filters.  Kurt
