Torque tube end gasket
Sheridan-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheridan-Utah Quote  Post ReplyReply Direct Link To This Post Topic: Torque tube end gasket
    Posted: 16 Feb 2010 at 2:38pm
Does anyone know  were you can buy the gasket that goes on the end the torque tube to connect the rear end to the transmision on the WC or RC
HANSEN'S OLD ORANGE IRON
We show, pull, & go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 4:33pm
Go to any auto parts store and buy a roll of gasket material the right thickness. Start drawing and cutting. If you don't have a hole punch, lay the gasket over the mating part and tap around the edge of all bolt holes with the ball end of a ball peen hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheridan-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 5:45pm
This is not a flat gasket.  It goes around the end of the torque tube.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 5:45pm
i bought one of those gaskets from the local Agco dealer a couple of years ago, cost just a couple of dallors more that a roll of gasket material.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 5:57pm
Your talking about a round thick gasket that goes around the torque tube and has a retainer with two slotted bolt hole in it so you can turn it tighter? If so when i restored my WC ten years ago this gasket wasn't available any more. So i took a rear main seal for a D17 and stuffed it in there. I did cut the sael a little shorter but it works and doesn't leak yet.  Matt
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 6:23pm
I used a large(fat) O-ring from our local Cat dealer on mine. I helped a friend work on one 5-6 years ago changing a tranny housing, and his had what was left of a toilet tank gasket with what looked like RTV all over it. It wasn't leaking, seemed to seal good.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 6:26pm
I have used grphite impregnated string packing, worked for me, I assume your talking about the retainer with two slotted holes.  Mark L
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 7:23pm
I thought you were looking for the torque tube to differential gasket. From what I have heard the torque tube seal to the tranny is no longer available. I found a quad ring at work in the misc. pile. It was a little too big, so I cut it on an ange and put the cut side to the top. I haven't ran the tractor yet but I believe it will work just fine. I had a quote on having cork cut to replicate this gasket, but didn't have buyers ready to justify the start up cost. Shuda couda wouda.
