snow plow for 712H wanted
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Topic: snow plow for 712H wanted
    Posted: 15 Dec 2013 at 7:43pm
does any one have or know were I can buy a snow plow for the 712H tractors? or is there another type out there that will fit it?
There are no atheist in foxholes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2013 at 8:08pm
Seth,
Watch e-bay. They're always poppin' up on there. Actually, there's a lot of different implements for the AC Garden Tractors on e-bay. Just keep yer' peepers open. One might come up in your neck of the woods....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2013 at 10:26pm
Keep in mind lots of blades will fit off all 700, an 900s just the lift rods are various dif lengths. Some yellow blades will fit if the lift bracket on blade is straight up and down. If its angled back it will hit frame of tractor.
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2013 at 8:40pm
I may have one I would sell, came with a 712 that I purchased. I haven't ever mounted it as the 712H is a grass cutter. I will take some pictures of it. I'm located 25 miles north of Grand Rapids, Michigan
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2013 at 8:49pm
I saw one on ebay the other day but it sold
wildbill26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2013 at 4:37pm
seth, i took a blade from an old cub cadet and made it work on my 710, the only modification i needed to make was make the hole in the lift arm one size bigger, i can send you pictures of it if you want to give it a try, i got mine for $20 and just cut it down to size to mount to the front axel and drilled some holes in the frame work, the lift rod was on the correct side already too
1950 wd wide front w loader
1940 b, 1939 m crawler
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2013 at 4:23pm
PM sent.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2013 at 7:09pm
here is one off of a B series tractor that with a little modification will fit a 712 , and can still be used on the B series.
Edited by ctbowles58 - 26 Dec 2013 at 10:12am
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2014 at 11:32am
what type of modifications did you have to make?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2014 at 11:56am
Don't mean to speak for you ct. Seth you see in the picture the blade lift bracket, how close it is to the front of tractor that's the part tha has clearness issues. And the length of the rods will be different. If you find a latter lift rod there usually adjustable. But the rods for the yellow tractors (at least all ours) are a set length and wouldn't work as is on yours. Hope this makes sence lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2014 at 4:17pm
you could probably just replace the rod with bailer twine
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2014 at 5:06pm
i used 1/4 in. chain with a clevis in both ends so i can adjust it if i need too, i have used this blade for 25 yrs like this and it works fine. i will get you some pics of what i done to make it fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2014 at 5:24pm
here is how i modified it, i cut the one brace off and welded a back bone on the other one to brace it, then i used a chain ti lift it with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2014 at 4:47pm
mmmmm I think I could do that. I don't have a welder but my uncle does. Thanks.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2014 at 7:36pm
So you already have a B-Series blade? All you need to find is a hitch or make the modification Tom suggested. Honestly though these blades are not hard to find. I know a guy in Illinois that would have one if you want his info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 1:12pm
No i don't have a B series blade but ill keep a eye out.
This page was generated in 1.554 seconds.
