w speed patrol info
jw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jw Quote  Post ReplyReply Direct Link To This Post Topic: w speed patrol info
    Posted: 15 Feb 2010 at 3:46pm
can anyone please post pics of where blade mounts onto turntable?I put mine on today and it seems awful loose maybe i am missing hardware.Thanks in advance joe.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 5:25pm
Hopefully these pics work out, let me know if you need a different angle or something. Mine is set at straight across right now. There is a 1" and 3/4" bolt in each side, don't know if that is correct or not but it works fine.
jw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jw Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 5:36pm
Thanks for the pics mnlonnie. Someone welded ears on the outside of my brackets where you have the bolts it looked like you just put a pin in for adjustment but it needs a little work.I like the idea of being able to adjust blade angle without unbolting 4 bolts.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 11:46pm
Mine has ears welded on also...I was told Spokane County had eleven Patrols at one time...mine was converted to hydraulics and power steering. I'm thinking the rest might have also and got spread around the country???
ALLIS EXPRESS!
This year:
This page was generated in 0.104 seconds.
