need sleeves for wd
kniesshy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kniesshy Quote  Post ReplyReply Direct Link To This Post Topic: need sleeves for wd
    Posted: 30 Nov 2013 at 9:51pm
in a pinch with sleeves...gave the motor to a guy tk bore n press sleeves in and he ordered sleeves that were wrong due to a pn change. it is a 4 1/2 bore by a 5 1/2 stroke engine...any help ?
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2013 at 10:50pm
What size do you have? If there 4in might be interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote kniesshy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 8:00am
they were 4 1/2 but were not long enough...sennt em back sorry
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 11:02am
I got your pm but i've been so busy I just haven't had 5 minutes of spare time to get back. You custom order sleeves from a sleeve manufacturer such as LA Sleeve, Darton, or Power Bore. I'd order ductile iron sleeves from Power Bore in Ohio, I can get you a blueprint of the dimensions I use as I need to send it to another fella. What I should do is get 12 or 20 of them made as there's a quantity break, I need some sets for this winters builds anyway. At times I make sleeves from take out sleeves from other engines, but I just don't have time and a ductile iron sleeve is much easier to work with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kniesshy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2013 at 7:32am
yes send the blue print if you can!if u need my email its dirt_bike77@yahoo.com
