WD45 Hydraulics
PennsylvaniaNewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PennsylvaniaNewt Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulics
    Posted: 14 Feb 2010 at 6:22pm
Can the WD45 be used to run a hydraulic motor.  If so what to do you do about a return line etc.  Or can you make it a complete loop system with a one way valve on the return line from the motor feeding or running back into the pressure line.
