allis chalmers hd7g
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers hd7g
    Posted: 22 Nov 2013 at 4:47pm
i have a allis chalmers hd7g that all of a sudden stops moving now after about 40 minutes of use. then you have to waite a hour and you can start back up and run for 40 minutes again and will stop moving anyone have this issue before. i'm just alittle confused as it pushes and lifts great and when it hits that 40 minute mark get ready cause it will stop moving. thanks for any help
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2013 at 9:27pm
  Sure sounds like cloggy filters. I assume you have gauges for the tranny like mine so, what are you pressure readings? Do the power brakes still have power when the machine will not move?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2013 at 3:28pm
I WILL CHECK GAUGES AND BRAKES AND LET YA KNOW its just weird acting. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2013 at 4:17pm
Corey is right, probably clogging screens/filters if they have not been changed in a while. I am currently updating my machine as the trans finally lost Rev altogether the other day. Have a trans and converter out of a donor machine going in soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2013 at 4:33pm
Corey, you have a PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2013 at 4:37pm
Kinghunter, dial down to page 3 this post for expanded views on 7G trans:
http://www.allischalmers.com/forum/forum_posts.asp?TID=78780&title=finally-got-in-a-good-day
This page was generated in 0.350 seconds.
