H-3 track parts
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Topic: H-3 track parts
    Posted: 20 Nov 2013 at 9:13pm
Wondering if there is any chance on finding drive sprockets? What about rollers? Could a guy build up and grind the old sprockets to suitable use? Thanks in advance, Trev.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2013 at 1:37am
Are you wondering about brand new sprockets or OK used ones? With lots of time, patience, welding rods and a grinder you can certainly improve old ones. I can sell you a whole parts machine if you come out to B.C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2013 at 9:32am
Rollers and idler can be welded up . Many track shops have submerged arc welders (wire feed with powdered flux) setups just for buildup work.
 Getting sprocket tooth profile right to align with bushing might be more work . Some outfits sell weld in cup that you position on sprocket then weld in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2013 at 2:50pm
Thanks for the info, Trev.
