Allis Chalmers K |
gvoerm
Topic: Allis Chalmers KPosted: 19 Nov 2013 at 11:40am |
Does anyone have a bronze throwout bearing/collar for the hand actuated Main clutch on an allis chalmers K? Or know of a source for these? If not is there interest if they are reproduced?
Grant |
everett048
Posted: 19 Nov 2013 at 1:05pm |
I think power units with the same motor have that through out bearing or try Norm Meinert he may be able to help clutch must have been disengaged and running for a long time to wear it out.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11871 |
Posted: 19 Nov 2013 at 4:21pm |
Parts should be available. It is most likely either a Twin Disc or Rockford Clutch. Some Rockford clutch parts are difficult to find. But it would be same as industrial clutch used on many OEM power units (most likely). Need more information. Flat flywheel? Bolt circle of the drive ring? Is there a plate with clutch information on it. |
everett048
Posted: 20 Nov 2013 at 1:36am |
No drive ring on K crawlers clutch is mounted on to first motion shaft with teeth around the out side of the plate that engage the toothed flywheel.Drive plate is semi floating untill clutch is engaged to clamp it up.It is clamped between two heavy cast iron plates.
Edited by everett048 - 20 Nov 2013 at 1:39am |
Norm Meinert
Joined: 31 Oct 2010 Location: Davis illinois Points: 470 |
Posted: 20 Nov 2013 at 10:17pm |
I have one for the k. the power unit is different size. call 815-865-5372
Norm |
