alternator vs tach
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: alternator vs tach
    Posted: 12 Feb 2010 at 10:45pm
 I am having trouble with my tach maxing out at half throttle on my 7060. It hits 3000 when it should be about 1500rpm. It has a different alternator on it and when I got it the tach wire was off. If the alternator was bigger or different would that cause it? I also have a 7050 that the tach runs at about 500rpm wide open and 300 idleing. What would cause such a low reading? Any help would be great
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 10:58pm
are the pulleys factory size?
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 11:06pm
 They look to be the original size, but im not 100% sure. The 7050 and 7060 both have the same pulley. The 7060's alt was rebuilt a couple years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 7:17am
Sounds like the new alternator has a double the number of poles compared to the original.That would give you exactlry twice as many 'counts' per rev. This could be confirmed ny knowing the part number of the original and 'new' alternator. A slightly different pulley size(say 2 3/4" vs 3") would give a slightly higher or lower reading.
hth
Jay
