B bearings opinions wanted
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: B bearings opinions wanted
    Posted: 11 Feb 2010 at 9:14pm
On my 1938 B I am trying to reassemble my journals on the spare crnak I had measure out
Front Main: 2.248
Center: 2.248
Rear:2.248
Rod 1: 1.934
Rod 2: 1.935
Rod 3: 1.935
Rod 4: 1.935
Shop manual says Mains: 2.2495 and rods: 1.937
My question is will standard bearings give me the correct clearance or do I need .002 undersized are bearings made so that once shims are installed they have the correct clearence and crush with the size of my journals will .002 undersize give proper clearence with shims installed and if I they don't what would happen if you removed all shims to get proper clearance
Thanks in advance for all help and opinions,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 9:43am
First you have to find out if the main and rod journals are round. Rod journals tend to wear more on the side with the power thrust. Most wear is just after top dead center on the power stroke. Then you need to keep the couple thousandths working clearance from the largest diameter and decide if more clearance is going to cause too much loss of oil pressure.
But .002 under bearing inserts are made for the case where the crank shaft is worn, but not too out of round. Its much cheaper and quicker to use those inserts than to grind the crankshaft. But then you can get that by removing shims though somewhere in that process the hole in the inserts isnot round either.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 10:12am
They are round and no taper either, the big thing I guess is if the bearings are made to have correct clearance with shims installed or if shims will increase clearance at which point I would need .002 bearings, I am fairly sure I will need the undersize on the rods anyway
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 10:32am
Good luck finding .002 bearings. A new shim stack is .010. 4 to a stack. Plastigauge and remove .0025 shims as needed using standard bearings.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 12:17pm
With this type of oiling systen you need not be concerened with the side clearance as long as you are not out of round on the journal.
I will place the link to pictures I took of the bearing filing which is what will be needed in your case.  The .002 clearance would be measured with the pistons at bottom center.
You measure the journal and then clamp the new berings into two rod caps and measure that diameter. You will want the inside bearing insert diameter to be .004 larger than the rod journal. That will give you .002 crush and the .002 clearance when properly shimed.
After filing the bearing inserts you will want to mark which journal you have fit the bearing to. They all look alike when you are done measuring and filing and you probly won't want to measure all over again.
Not filing th einserts will crush th ebearing inserts enough to crush the inserts at the parting line and pus th ebearing in towards the rod journal and lock the crankshaft from turning.
The pictures are not in order so you will have to fish around to see what I was doing.
Edited by Dick L - 12 Feb 2010 at 12:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 1:20pm
Denis. Listen carefully to Mr Dick L. He has it all together when it comes to B/C&CA engines. When he quits posting replys it will be a great loss to the forum and the hobby.
