Agco Allis 918H question
Orange918H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange918H Quote  Post ReplyReply Direct Link To This Post Topic: Agco Allis 918H question
    Posted: 05 Nov 2013 at 11:27am
New to the forum today not sure if there a intro ?
my question on the Kohler Command
I have a 1996 Agco Allis 918H garden tractor
 it has a Kohler Command 18 hp engine it ran great
for most of the 8 or more years i've owned it
last year it started smoking but ran the oil leave dropped
then you had to check the level daily and add oil
the right front of the cylinder showed oil residue
build up from years of use
one day while it was running i saw gas spurting out the same area
watched some youtube videos for ideas and help
after the videos i was hoping for a blown head gasket
so that's where i'm at
i have most bolts removed and shields but not the cooling shroud
went back to the video found out i didn't remove the 2 intake bolts
so i'm at that point wondering if the can be removed with the shroud
in place? if not what's involved? removing the engine?
do not know what and where the bolts etc. are located or what must
be removed and what does not
so any help i greatly appreciated since i'm in Minnesota and snow is in
the forecast today i need to get going
p.s. - any thoughts if it's only a head gasket or rings etc.
Thanks Rich
chuck linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck linn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2013 at 6:18am
 Go to kohler web site and download service mannuel most likely head gasket
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2013 at 9:22am
I have a new service manual for the Command series if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange918H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2013 at 9:44am
Thanks i'll check the Kohler website
got snow last night luckily it was just over a inch
here's hoping it a head gasket
Thanks again for the info
Edited by Orange918H - 06 Nov 2013 at 9:46am
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 7:01pm
I have verticle crank kohler comand 18 hp . Had a serious oil leak, I was ready to replace it , dealer handed me a small square gasket for small plate in between the two heads under the intake ,it fixed the leak . He said they all leak after a few yea
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange918H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2013 at 1:44pm
Today i ordered a Kohler #24 841 01-S head gasket kit
after using my back up 40 year old Crusader MTD USA
built  5hp snowblower i thought it's time to get going
on my Agco Allis 918H
the 5hp did not eat up what the county snowplows
left at the end of my driveway
my 918H ate that for breakfast even if it was old frozen snow chunks
my U driveway it's roughly 250 ft by 10 feet wide
funny how a guy gets going when the real snow & cold
come and you get a face full of icy snow and frozen fingers
the good if it get real bad my neighbor cleans out my driveway with his Bobcat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange918H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 10:38am
update - 1st of all i should say my tractor is not
up in the air so i can get under and see what's going on
it in my garage which is a mess loaded with
every thing i wanted inside with the snow coming
which has arrived
the mower deck is still under it & my jack stands are under
my 50 Olds 88 so i need to borrow some stands
question on removal my 18hp horizontal shaft  engine
from the hydrostatic drive unit on my Agco Allis 918H
i did download the manual found out there are 4 mounting bolts
to remove but i did not see any thing about separating engine
i check around and i think taking 2 bolts out at the flywheel was
mentioned so is that what i need to do? or is there more things
i have to unbolt?
right now it's nasty outside -4 with -35 wind chill coming
so i'm not going in the garage any to soon
the other thing the engine is dirty from years of cutting grass
and dirt thrown up and sticking on the oil leak
i'm gong to spray it down with carb cleaner i can't even see
the mounting bolts
when i do get it clean i'll keep it clean - lesson learned
Edited by Orange918H - 09 Dec 2013 at 12:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange918H Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 5:09pm
Pulling the 18hp engine
what's the easiest method to be disconnecting the driveshaft on a 918H
do you have to remove all the bolts
i just saw 2 at the rear of the engine i assume there 2 on the
opposite side
couldn't find a diagram to look at
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange918H Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2014 at 5:14pm
Well i finally got the engine out Clap only took 6 months
reason -  it was covered in grease could see much
and the biggest thing was lazy
so the head gasket was blown on the right side as expected
got every thing figured pretty much now, just a lot of clean up to do
i took carb cleaner and blew out the head bolt holes worked ok
until i did the top left hole with the most fins -
the carb cleaned was shooting out the fin mid way down to the rear
i hope that is tapped through the block from the factory
and that's why this is happening - need some advice on this - Thanks
Edited by Orange918H - 19 May 2014 at 5:16pm
This page was generated in 0.344 seconds.
