715-B back hoe understanding
Eric Rollin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Rollin Quote  Post ReplyReply Direct Link To This Post Topic: 715-B back hoe understanding
    Posted: 02 Nov 2013 at 8:48am
I am trying to find out what year the Allis Chambers back hoe i purchased is.
The model is 715-B
also described on name plate is that the machine is a 715-D
serial number is 1800's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 8:58am
1976 - Srl # 1759 to 1937
Overall from 1973 Srl #1001 to 1983 Sel # 3468  ( some may be after this but no record)
AC 710 and 714 were built in 1982/83 and shared the AC 715 Srl# series.
Edited by Coke-in-MN - 02 Nov 2013 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Rollin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 9:15am
thanks - don't suppose you could point me to a location for supply of a service/parts manual for same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 10:06am
Check on here if Daren has any or some of the other posters or I found this one using google search for AC 715-B TLB.
 Minnpar stocks parts for the machine -
  1. Manuals Manuals Manuals A great collection of Manuals - Scribd
    www.scribd.com/.../Manuals-Manuals-Manuals-A-great-collection-of-Ma...
    Aug 12, 2013 - Blue Ribbon IH B-275 Tractor Chassis Service Manual GSS1241 Blue Ribbon IH ... 1 Tractor TLB Parts Catalog Manual CASE 580K Prior to JJG0020000 PHASE 1 ... 702B 710B 712B 715B Tractor Workshop Service Repair Manual Case 730,... HP 403B AC Voltmeter Operating, Parts & Service Manual -.
Yooper Rod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yooper Rod Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 4:09pm
The backhoe I bought was sold as a 1982. Some of the information on the nameplate is: NAME 715-B-B/L MODEL 715-D SERIAL 2756. There is another serial number, which is LD2268LU656327G. Does anyone know if this has the Perkins or Cummins engine? Also I'm assuming the transmission is a Borg Warner T-18 and the shuttle is a Borg Warner T-72, would this be correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 4:18pm
right on the trany and shuttle .
Picture of pump brace needed with the Perkins engine - pump will crack front housing without it - I made this one but there was a factory update of fix out there also .
A
A
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 4:23pm
Rrl #2756 would be 1980 (#2661 to 2889) It would have the Perkins engine .
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 4:28pm
Srl # plate on mine - I have a Dig-More extenda hoe on mine so digging depth is 18' rather than 14' of standard 715B - D
Edited by Coke-in-MN - 02 Nov 2013 at 4:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yooper Rod Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 4:41pm
Much Thanks, Coke. This Information will be very helpful. And thanks for the pic of the serial plate, mine is wiped clean except for the stamped numbers.
I found a place to get the parts to rebuild the shuttle, Herculift Manufacturing in Schofield, WI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2013 at 5:04pm
Herc U Lift here in MN was a good source for parts and info as they sold the machines .
Another poster on here has the kits also and had a good price on them - might check back in posts to find him.
Can tell you I had mine done as I needed the machine quickly - Had CARLSON TRACTOR in Rosemount MN do it - They ripped me off something fierce - charged me 40 hours of work and extra for parts - I had a complete rebuild kit I got when I bought my machine --- So me and Carlson have parted ways - BUNCH OF CROOKS .
 So I paid over $4,000 for nothing as the unit failed within 30 hours of use . They questioned my check and told me they were going to hold machine until check cleared - when I said I would call Sheriff - they backed down and let me take the machine.
This page was generated in 0.535 seconds.
