Wanted a starter generator
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Wanted a starter generator
    Posted: 01 Nov 2013 at 9:13pm
I need a clockwise rotation starter generator to start a 10 hp Kohler.
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2013 at 12:14pm
What did a clockwise starter generator fit? What do you tell which direction it is set up to run?
  David from jax
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2013 at 4:38pm
Quite a few older garden tractors had starter generators. Some ran to a pulley on the front/flywheel of the motor and would be clockwise and some ran to a pulley on the rear of the motor (opposite of the flywheel) and would be counter clockwise. I need one for a 10 hp Kohler K241 that wasn't made with one.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2013 at 7:37pm
  most are clockwise   cub cadet are counterclockwise?????????   which one  both are k241  been there done that
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2013 at 7:38pm
 forgot phone 1-574-342-4545
