Craftsman/Simplicity/AC cab for sale
macvette View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Topic: Craftsman/Simplicity/AC cab for sale
    Posted: 31 Oct 2013 at 8:37pm
Says Craftsman on an orange cab, but previous owner said he had it on his Simplicity.  I bought it thinking I would put it on my AC 620, but after looking at it further, decided I didn't want to cut the door framework up and rework it enough to fit my square fendered tractor.  The cab is wide enough that it would have fit my 620 - which is similar to the Simplicity PowerMax.
Has a burn thru hole near the front of the canvas side cover - probably from muffler. Clear flexible plastic "window" low on front side is also cracked.  The front window, rear window, as well as both side windows on the doors are intact in good shape- not cracked. Doors closed properly before I dissassembled to transport cab home.  Fibreglass top is in good shape as well.  Canvas is in good shape with the exceptions I mentioned above.  I can send pictures via email if interested.  May fit other tractors as well. All brackets seem to be there, but don't know for sure as I never mounted it on tractor.
$75.00
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 9:15pm
Can you send a pic or two?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 11:57pm
Will take a couple tomorrow and send to your email. It is dissassembled, so will try to lay it out so you can see all sides.
This page was generated in 0.085 seconds.
