B lifters
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: B lifters
    Posted: 10 Feb 2010 at 8:01pm
My B has 8 trashed lifters that are so bad they can not be refaced I am looking for some useable ones and found some for a D-15 gas, will they fit in my 1938 B.  Also are all cam beaings the same for all BE and CE engines the parts guy said the ones they can get are for a certain serial # up B64501 is their a difference or will they fit my 1938 engine. Also is their a good place to get new O-rings for the sleeves or are they something that can be bought at a hardware store.
Thanks in advance for any help or opinions,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:18pm
The parts book I have shows the cam bearings to be the same for all Bs, IBs, Cs & CAs. Two sizes.  Standard and .0025 undersize.
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:19pm
Denis I'm parting out a B and may have what you are looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:22pm
What year B, I need alot of parts but the engine is my first concern at the moment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 8:00am
It's a 1954
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 8:09am
At the risk of sounding like a fool the lifters are suposed to be like those foundin most other engines right, with a convex face as opposed to the concave face all of mine have.
Todd what shape is the trans in I think mine needs a shift fork, it locks up between 1st and Reverse sometimes when you shift between them, and I will probably need some other parts for the trans and rear too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:31am
LOL! Your guess is good as mine on the lifters. Trans as far as I know is fine. Rear all there and no known noises.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:58am
If your lifters are cuped or dished out and not flat faced the cam is probably shot also. Inspect the cam lobes for ware. If the cam is OK be sure to check the oil pump drive pin in the end of the cam. Replace the pin with the cam out. Sometimes a new pin the same diameter fits too loose. Go with a bit larger pin and widen and square up the slot in the oil pump with a flat file for the larger pin. That slot gets notches worn in it too.
   I have torn down several B/C engines and wonder how they even ran at all before they quit running for good. If You are finding serious ware to the cam and lifters the rocker arm shaft is more than not also shot. New ones are big bucks. New rocker arm bushings are not available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 10:24am
I got a NOS cam as the old one was completly shot but valve train seems ok so far
DocsEquipment,IL. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DocsEquipment,IL. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 10:46am
i also would have lifters and a shift fork Doc 309-246-2900
This page was generated in 0.065 seconds.
