H-3 radiator
tom38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Topic: H-3 radiator
    Posted: 22 Oct 2013 at 6:45pm
could anyone out there tell me if a D14 tractor radiator will interchange with a H-3 dozer, or does anyone have a good radiator for sale. thanks in advance tom
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2013 at 7:17pm
The H3 is based on the D15, not the D14, but I'm not sure what parts interchange. Someone should know or give us some dimensions and we can compare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2013 at 7:39pm
I think this question was on here earlier this year.  I measured my D-15, and it fit, IIRC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2013 at 8:48pm
I said the d-14 because when I too my rad. out because it leaked like a sieve on the top front of the tank is marked in yellow crayon, like a junk yard uses. A C-D14 SO I assumed it was out of a d14 but they might have made a mistake and marked it wrong. that is why I'm asking so if I have to order a new one I'll know it will fit. tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2013 at 9:17pm
one more thing the radiator fit in with no apparent modification done to it. It measures 19&one eighth wide by 23&three fourths high to the top of the fill spout. tom
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2013 at 3:16am
The difference between a tractor radiator and a dozer one is the length of the fan shroud on the back of the radiator the tractor one is longer
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2013 at 6:25am
So, if you had a D15 gas tractor radiator (not a D14) you could pretty easily trim down the shroud depth to fit. There's no way a D14 radiator fits an H-3......has to be based from a D15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2013 at 8:05am
thanks a lot for the information that helps a bunch because this radiator has the shroud trimmed down thanks again tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2013 at 5:44pm
Yes it would be a D15 radiator not a D14, the 14 is way too small
This page was generated in 0.168 seconds.
