three point to snap coupler
PennsylvaniaNewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PennsylvaniaNewt Quote  Post ReplyReply Direct Link To This Post Topic: three point to snap coupler
    Posted: 10 Feb 2010 at 10:31am
Has anyone ever converted a three point piece of equipment to snap coupler.  If so does anyone have conversion photos
Bill (E.C.MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 12:27pm
Newt,
A-C made an adapter just for this.  I have a couple of them, an original and a newer aftermarket one.  They work great.  Here's a drawing from an original manual.  The top link isn't shown here, but it simply pins to #3 and attatches to the upper link on the implement.
A-C's currently on the farm: B, CA, 2 D-17 D's, One Eighty, ass't implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PennsylvaniaNewt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 12:47pm
Interesting!  It looks like the toplink would be in the way of a PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PennsylvaniaNewt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 12:49pm
Any pix of this installed?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 1:28pm
Here is a bale carrer and a AC three point setup.
N.C. Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N.C. Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 1:37pm
There are some pics in the thread link below  of one of these adaptors on my WD45. Here's the link: http://www.allischalmers.com/new/forum/forum_posts.asp?TID=4261&KW=&title=factory-ac-snap-coupler-to-3point-adaptor
'57 WD45, '47 B, Massey-Harris 60 SP Combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote PennsylvaniaNewt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 1:45pm
Wouldn't the top link hinder hooking up a PTO ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 2:05pm
Yes, it would.  That arrangement only works on non-pto implements.  For pto implements, the cross-tube would be removed and a tractor-mounted bracket installed to accept the top link.  The nice thing about the cross-tube arrangment is that it can be left on the implement for easy snap-couple hookup, it truly converts the 3-pt implement to snap coupler.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 2:05pm
I have an operators manual for the different types of hitches that AC offered.  Sold a bunch of copies to folks on here a few years back. There are two main styles. One is an adapter that attaches to and stays with the implement.  It is made for non-pto driven equipment due to the fact that the top link is in the way. These are easy to spot since they don't have swivel balls in the lift arms....just a hole since there is no "sway" between the hitch and the implement.  The other adapter is the one pictured and is made to stay with the tractor. If pto equipment is to be used, a top link bracket has to be mounted on the tractor.  These brackets vary depending on the model of the tractor. On non-pto equipment the top link can be angled down to the crossbar on the adapter.
ALLIS EXPRESS!
This year:
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 10:00pm
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 10:28pm
I don't have much for pics any more but my Dad made a tongue to bolt on to a 3pt blade.  I resized these photos for tractorpics years ago and no longer have the originals or the tractor.
Edited by Claus - 14 Jul 2010 at 10:30pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 7:19am
Have Adapter in good shape here if needed, I know of a load leaving here to PA, maybe hitch a ride??
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 7:32am
I've been running a 3pt snow blower using that set-up on my 190 snap coupler tractor. I got a top link bracket for the tractor from a salvage yard, so I hook that just like a standard 3pt, and it is out of the way of the pto  shaft. I still leave the arms on the blower when I unhook it,I just rest them on a jack stand that is set at the right height for the snap coupler bell. Makes it a "snap" to hook and unhook" LOL!  I don't know if it is the right thing to do or not, but I put the draw bar bail back on, and it works as sway blocks. (that would only work on a D 19 or 190). Blew snow yesterday morning with it for 2 hours, and other than using a tanker load of gas, it worked good. Darrel
