4.5" Crank in a 201 block |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Topic: 4.5" Crank in a 201 blockPosted: 21 Oct 2013 at 4:10pm |
What is involved in putting a 4.5" stroke crankshaft (from a WD45) in a 201 engine. Is it a simple bolt in, or is there other things that have to be changed or machined to make it fit?
DrAllis
Posted: 21 Oct 2013 at 4:23pm |
Crankshaft bolts right in. Pistons and sleeves will probably need to be replaced due to higher piston travel. This causes higher compression AND if your sleeves are worn and have a ring ridge, you can't shove the pistons up thru that ring ridge without breaking rings, piston lands, etc.
WF owner
Posted: 21 Oct 2013 at 7:34pm |
I plan to replace sleeves and pistons. I would like to go the 4.125 sleeves and I was thinking of 170 pistons and maybe a 170 cam. What other issues will I need to be aware of?
mike a
Posted: 21 Oct 2013 at 10:17pm |
175 cam is what you need ,not 170 cam.
