Choke cable or rod on d17 carb?
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: Choke cable or rod on d17 carb?
    Posted: 08 Feb 2010 at 10:17pm
1959 D 17 I am not sure how the original way of operating the choke, when I got it the cable or rod was gone. I have a cable but not sure how it is originally set up. I can make a bracket to make it work but would like to do it original , carb is original. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:19pm
Would anyone know of a picture of how it is set up? pictures are easyer to explain sometimes. anything will help
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:25pm
1959 would use a rod to activate the choke.  Runs from the carb and comes out the shield under the gas tank.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:25pm
I have a 59 D17, it is a rod it attaches to the engine side of the carb, and extends to the left side panel below the gas tank. There should be a slit about 3-8in wide and about 2in long that the rod will stick through with a screw on ball. I do not have any way of taking or posting pics so im no help there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:38pm
My 1958 D14 is the same set up - the knob to the right of the decal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:44pm
Got it i will maybe have to make one. Does anyone have any side panels for a D 17 like the one on the D14, I need a set.thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 7:02am
Is that rod 2 pieces? That looks just like the shut off on a D17D. The diesel shut off is 2 pieces anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 7:09am
Gas choke rod is one-piece and on all D17's prior to series 3.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 8:54am
You can obtain aftermarket side panels from Norm or Doc's Equipment. There may be other suppliers who advertise on this site who can also provide them.
RGR(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGR(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 10:54am
I HAVE A ROD FOR A D17 GAS.WOULD YOU LIKE A PICTURE OF IT OR DO YOU WANT TO  BUY IT? $25.00 PLUS UPS
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 12:26pm
I made a bracket and hitched a choke cable that I already had up to choke on carb and it works really good I put the choke control in the light switch hole(clutch side) and moved the light switch to the brakes side.  I have a bad habit of revising and retooling different parts on equipment, sometimes it works and sometimes not.  Thanks anyway.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 7:38pm
  we have choke rod and the side panels both  1-800-254-3116 for ordering   visa--master cards
alan1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 3:11pm
Could you send me a picture of the choke rod off the D17 Allis? Thanks so much!
