Need Carb for B-1
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Need Carb for B-1
    Posted: 10 Oct 2013 at 8:18am
Looking for carb for b-1 with model 19 engine.
Can't fix stupid
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 8:30am
Have you checked Ebay at all? I got one for my B110 a couple months ago as well as my 608. Any B-series carb should work for your B1. Also, cross reference the B1 to Simplicity model numbers-may get you more choices. They are the same machines basically.HTH
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 9:06am
Yea I have tracked down the part number. New carb is bout $100 plus. Just seeing if I can find a used one first.
Can't fix stupid
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 6:42pm
Is it a Briggs engine?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 8:38pm
Yup.
Can't fix stupid
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2013 at 12:15am
You need a 3 screw carb from the model 19 through the 23D.  What is wrong with your carb?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2013 at 8:11am
It's missing. Not there, grew legs and walked off. I saved this mower from the scrapper.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2013 at 6:57pm
Then you need more than the carb. You need the air cleaner and air cleaner base too.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2013 at 9:34pm
I have the cleaner and the base. Carb is the only thing missing.
Can't fix stupid
This page was generated in 0.127 seconds.
