170 gas
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: 170 gas
    Posted: 08 Feb 2010 at 7:34pm
Does a 170 gas have cylindrers that are replaceable? Also how do you remove the enginefrom the frame? the front motor mount completly encircles the power steering assembly. Do I have to split the tractor at the bell housing?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 1:57am
A 170 has the same engine as the D17. When i rebuilt mine, yes the sleeves are replaceable, and the bracket came out with the engine. After the engine was out the front pully came off then the front motor mount will un bolt. I slpit mine at the bell housing first and rolled it forward then took the engine out of the frame.
This page was generated in 0.410 seconds.
