Pole Barn Question
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Pole Barn Question
    Posted: 08 Feb 2010 at 11:19am
I am having a 30' x 40' x 10' pole building built this spring by a contractor-----will have county building permit. The sides will be metal as will as the roof.
The roof will be 5 pitch with trusses 4' on centers and 2' x 4' perlins with 7/16' OSB and metal roof on top of OSB.   Question for you folks--what do think about trusses being 4' on center with  it carrying the weight of OSB and metal sheeting ? It will be approved by county engineers.
Tks
Steve
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 11:31am
Here I put the 2" x 4" on edge when the trusses are on 4' centers and lay the 2" x 4" flat on 2' centers.
The truss builder needs to know what and how to build in snow load. The contractor probly has it covered or at least should.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 11:49am
OSB is HEAVY! My three machine sheds without OSB have trusses at 9 or 10 foot intervals. Those trusses are made of large 2x, no 2x4 tops or bottoms. More like 2x8 or 2x10 and are made of the best quality lumber. Really beautiful lumber. The 2x4 purlins are on edge in all of them.
Why the OSB?
Gerald J.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 11:55am
I had a 32 x 48 x 12' building put up this past summer with three 16 ft bays, and a 2 ft overhang all around to help keep things dry.  Trusses are similar pitch to yours and are engineered for 4 ft. spacing with 2 x 4 purlins and metal roofing on the purlins (no OSB).  It has held up well to some strong winds and now a bit more than 2 ft of snow.  As you will hear from lots of folks, the only thing I would do differently would be to make it 64 or 80 ft. long...
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 2:20pm
Steve, You might want to ask your contractor how many inches, center to center, that he is figuring for the 2x4 purlins.  With the additional weight of the OSB plus sheet metal over the 4' span, you may want to decrease the distance from say 24" down to 18"?  Or, you could put 2x6 purlins every 24"?  You may also want 1x4 flat fur strips on top of the OSB to nail or screw the sheet metal.  These 1x4 spaced at 2'or 3' would allow the sheet metal to flex some & offer an additional air gap for insulation purposes plus it wouldn't add much expense.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 2:42pm
Steve when I built my pole building, we use 4' spacing for the trust with 2 X 4 s on edge, then paper for a moister barrier, then the metal screwed down. It is a 4/12 pitch and has held the snow load well.
Tom
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 3:55pm
Tks
Steve
Just tell your truss manufacturer what you  plan to top them with and they will do the rest but sounds like you should be ok.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:36pm
If your using metal roofing, why OSB? I see no advantages
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:51pm
I worked for a truss company for 2 years.  just make sure they know the loading and spacing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 9:24pm
OSB for a vapor barrior.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 9:32pm
You can save $$$$ by using the 2" insulation blanket instead of OSB.  My 40 x 84 barn is built on 12' centers with 2x8 gerts set between double trusses with joist hangers. Snow load is 40#...standard design for our county.
ALLIS EXPRESS!
This year:
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 9:43pm
NO actually the OSB is less per square foot than the insulation
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 9:47pm
But the underlying framing and trusses are more expensive.
ALLIS EXPRESS!
This year:
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:57pm
..that same thought crossed my mind ? why ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 6:27am
My 40 x 70 x 14' shop has trusses every 12'(4/12 pitch),built in 1963,'old school',still straight,level and plumb! Roof has 3 x 4 purlins every 2',sports a metal roof.That leaked so the previous owner layed down 1/2" plywood and 2 layers of shingles.
Last summer all the shingles came off and a new single layer went down.
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 7:22am
Seems to me if you are having it built by a contractor, it should be code. If not, make him rip it up and replace it at his expense. I highly doubt he will build something that will fail. That's my two pennies.
Brian
JimVH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimVH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 7:49am
It seems to me that you should be asking the questions of you contractor.  He is the one who should be aware of your local requirements as to loading and building codes, and also is the one to stand behind it.  If you do not have confidence in your contractor, then perhaps he is not the best choice to build it.  There are numerous methods of building a post frame building, and some are better for specific uses than others.  Compare methods with your contractor, and let him give you the best advice for your situation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 8:45am
I don't understand the vapor barrier idea. OSB will come apart after being exposed to "vapor" and water condenses on the inside of the steel, given high humidity and the temperature below the dew point. OSB will not stop condensation on the inside of the steel. Our new Barn for the tractor club has 4 inch panels of foam insulation and OSB on both sides. Then there is a layer of 1x4's to stand off the steel roofing.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 8:46am
OSB is heavy, id go the styrofoam sheets for a vapor barrier, may cost a little more, but will work better, and a lot lighter. you need to keep the roof itself as light as possible, there shouldnt be an issue with the purlins faiing, It is usually always the trusses that fail from snow load or weight.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 9:19am
OSB will not work as a vapor barrier. any time you put steel over wood you need a vapor barrier to prevent the wood from rotting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 10:13am
Eldon:  Making a statements  like "You can save $$$$$ by using a 2" insulation blanket" and "underlaying framing and trusses are more expensive" indicates you are knowledgeable enough to make an argument, but have not checked the facts.  OSB is less per sq. foot than 2" insulation.  The extra load carring capacity of the truss/purlin structure needed to carry the OSB  would be so small ,that it would not even be a factor.  7/16 OSB = 1 lb./sq ft. This is 1/40 of the engineered load carring capacity  of the roof structure.  To use "underlaying framing and trusses are more expensive" as a consideration not to use some kind of sheathing OSB, plywood or wafer board would be a statement to be made for the sake of argument, but not based on engineering facts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 10:23am
At a recent home show, I saw a metal roofing made to prevent condensation without any other liner. It was flocked with a fabric like fuzz. The pole building salesman said that was to prevent condensation. Not much insulation but some. He did not try to sell me a building because he had failed at that a few years ago.
Gerald J.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 3:42pm
I built my pole barn myself. used 2x8 rafters with 2x4 purlins 24"O.C., then steel. When weather and temp are right, it's like raining inside. But that's not a problem.
When I built my 28 x 40 shop, I put 1/2" CDX plywood over the rafters, building paper (tar paper), 2x4 purlins and steel roofing. I didn't want it to "rain" on the loft. And it doesn't. Steel roofs result in condensation so the vapor barrier is important if you don't want moisture. Leave the OSB off if you don't use a vapor barrier but plan on some dripping.
Bob@allisdowneast
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 5:25pm
Roof on my barn is 5/8" cdx, Tri-flex and metal. There are condensation channels in the metal to drain water away. The Tri-flex is essentially a water-proof membrane. According to the local metal roof guys, that roof is good for 40+ years.....well past the point where I will be using the barn. Why the plywood? We have wondrous new snow and wind load requirements here in Massachusetts.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 9:12pm
If you use osb you need a water barrier between the metal roof and osb.  It will be damaged otherwise. I would consider some 1/2" fanfold Styrofoam.  Installation cost will be lower for it in saved labor and material cost should be lower when you take the OSB + vapor barrier cost into account.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 9:29pm
One thing no one has mentioned is if you use the shed to work in it won't sound so bad during a rain storm if you have some kind of insulation in the roof.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 6:29am
My barn is surrounded by oak trees.....gets pretty noisy in there when the acorns start falling!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:47am
Dave, Not to mention the gray squirrels chasing those acorns across the roof. Those little claws could be like chalk on a blackboard.
Bob@allisdowneast
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 1:56pm
Bob, ya could be right, though I didn't see any of the wee buggers last fall when the nuts came down! I do know that the roof got mighty slippery - I think due to pollen and dust - not sure even the squirrels could stay on it.
WC, CA, D14, WD45
joe(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 2:49pm
I built a pole barn 5 years ago in northern wi. Spend the extra 200.00 and go with trusses 24" on center. I used attic trusses for the extra storage. I applied 7/16 osb, roofing paper and then put my metal over the top. You do not have to worry about any snow load, first warm day it will slide off. This is the second one that was done this way and we would not do it any other way. All the holes for the roof were pre-drilled on the ground on the overlap. This allowed me to hang the 22' pieces by myself. -Joe
