D17 slipping in road gear
wrbewley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Topic: D17 slipping in road gear
    Posted: 05 Oct 2013 at 11:55am
My d17 puller is slipping in road gear, is there an easy way to get rid of the power director, or should I try to repair it, not looking to spend a ton of money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 12:07pm
How do you know it's the hand clutch ??........high side or low side ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 12:16pm
I put a brand new custom clutch in it, it is slipping in 4 high
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 12:26pm
Well, you start by removing short shims from the high side (rear) of the hand clutch and installing equal amount of long shims in the center. Not there, but I'd remove .020" to start.  So, it handles the low side of 4th gear just fine?? What weight and HP you running?
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 1:18pm
If you have to much power you could put a D19 clutch pack in it. They have more clutches my Uncle did it to his turboed 175.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 4:13pm
I'm trying to run 4500-5500, we are guessing the engine to be around 120. Is there a good way to remove the clutch pack entirely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 4:31pm
Just an opinion but at 120 hp id try to keep it in ,it may come in handy just in case you need a lower gear ; either a D19 pack or different discs material or ive heard of running them dry ;
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 4:51pm
Is the d19 a direct fit, with out it would I be on the low side of speed or higher.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 4:55pm
Yeah, sure.....split it. Buy a 21-spline 1 1/8" PTO coupler(1000 rpm) and use that to connect the clutch shaft and trans input shaft.  120 HP at 4500 RPM shouldn't be a problem ( same as 60 HP at 2250 RPM) with the hand clutch if it's shimmed tight enough. 5500 RPM will help have the hand clutch explode if you do it often enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrbewley Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 5:09pm
I won't be running much over 2700 rpm,with out the clutches would it be like I am in high or low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 5:15pm
With the 1 1/8" 21-spline coupling it is DIRECT drive (high side). If you want low side, that can be done too, but it's pretty mucn one or the other.
