Roller dissasembly HD11
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Topic: Roller dissasembly HD11
    Posted: 05 Oct 2013 at 9:58am
HD11 E - Serial 8788
After I got my newly purchased dozer  in the air, I found 2 trucks with destroyed bearings. The previous owner had been driving this thing in bad condition for a while as there is quite a bit of wear on each end of the roller.
My manual, while covering the HD11, has an exploded view of an HD16 roller. The drawing shows that the shaft should be a 3/4 half moon at each end. The shaft on my rollers is round . So it uses the square block to attach the assembly to the dozer, rather than the pictured half moon mounting bracket.
Just inside from the attachment block is a flange. That flange or retainer has been severely worn by being used with failed bearings. It does not appear to be threaded on, but it's also set in close enough to the wheel, that I can't use a press to push it apart.
So I can't remove the shaft and get at the destroyed bearings...
Can anyone provide instruction on how to disassemble this?
Thanks
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2013 at 9:12pm
I would get some good used rollers. You will need a Serial Number, if it is above 10,000 it has the later style undercarriage. If it is less than 10,000 serial number, HD-9 rollers should also work. There are several posts of HD-11 parts.
This page was generated in 0.210 seconds.
