Rear wheel weights
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Topic: Rear wheel weights
    Posted: 07 Feb 2010 at 10:40pm
I bought a pair of weights at the salvage yard this past fall that came off of a 7040. I intend to install them on my Two Twenty, but I am curious what they might weigh. I suppose I could haul one to the  Co-op and weigh it and my pickup together, but maybe some of you guys have experience with them. They are as stated from a 7040, they are 8 1/2 inches thick, with an outside diameter of 31 inches, and a center hole for clearance on axle about 12 1/2 inches in diameter. They are very substantial chunks of iron!
They also had some of the 450 pounders there, but these were in my price range. It is going to be a challenge getting them mounted. This is the only photo I have at the moment.
Edited by redline - 07 Feb 2010 at 11:01pm
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:22am
If my calculations are right, they should weigh about 1250 lbs.  I don't think I've ever seen any that big.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:29am
I could believe the 1250 lb. estimate. Thank you. Here are some fresh photos from this morning.
Thanks for the help!
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:44am
Mike I think they wiegh closer to 1500 we had two sets come in on 8070 and a 220 and they sure could bendthe end of the forks could be wrong though Niel
jeffnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 8:57am
redline, just curious what the salvage yard wanted for the 450 ones, sitting on 10 of them and wanted to know what I had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:24am
I come up with 1399.06 not subtracting for the bolt holes, the small turn on the OD, or the shallow C'bore. So my guess would be 1350lbs. Now all you need to do is weigh them and tell us who wins the prize. LOL Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:52am
If I remember right, they were asking $150 a slab. I am not real sure on that, though.
It seemed like enough to me at the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 10:54am
I am not sure what kind of a prize to offer. Maybe the opportunity to help install them? I will see if I can get them to town sometime to weigh them.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 11:04am
FORKLIFT!!!!!!
"Burgie"
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 12:02pm
.2833 lbs/ cu. in.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 2:02pm
Those are some SERIOUS rear weights!!!  Better have a stout forklift fork.  Neat find!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 3:12pm
If Bretts numbers are correct then Neil might have a closer estimate. Any way that is some serious ballast.
mark/indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 4:19pm
remember to have some serious bolts to mount these...good luck, Mark
mark/indiana..."My favorite Allis Tractor or Crawler is the one I'm sitting on at the time!!..
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 4:29pm
Better get  before and after pictures of your FINGERS  before you mount those..lol..
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 4:55pm
That reminds me of a Red/Green episode where he is using a mitre saw. Red looks directly at the camera and says, "Be sure to count your fingers before and after each cut, so you know if you should be sifting through the sawdust." I, of course, winced when he said that.
"If the women don't find you handsome, they should at least find you handy."
I really enjoy that kind of humor.
