hd5
wildbill26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Topic: hd5
    Posted: 22 Sep 2013 at 10:30am
Im going to go look at an hd5 and wanted to know if there is anything special I should look at, its the one on eBay, its just 20 mins from me, and I always wanted a crawler loader,, I have run a cat 955 and d8 and d9 so I o know some about tracked equipment thanks
1950 wd wide front w loader
1940 b, 1939 m crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2013 at 1:48pm
TRACK - as with any crawler - undercarriage is the # 1 item
Then when a machine was made say 60 years or more back - lot of things wear out or become marginal.
 rear housing and oil leaks be they on transmission or on the final drive system .
If a G series then the loader linkage and cycle of the hydraulics for smooth and normal cycle times. (Hyd pump should load engine at end of cycle to almost kill engine if pump is good )
Master clutch should feel positive with a SNAP in and out, steering clutches should allow each side to stop drive and machine to turn it that direction slightly . When clutch is pulled for turn to side and brake is applied a stop of the track and quick turn should be felt .
Edited by Coke-in-MN - 22 Sep 2013 at 1:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2013 at 4:13pm
Thank you coke for the information
chumduffy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chumduffy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2013 at 9:39pm
WildBill I also have a nice HD5 dozer I would sell.Chum
