results 1st pull with 185 tonite
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Topic: results 1st pull with 185 tonite
    Posted: 20 Sep 2013 at 9:49pm
pulled the 185 tonite for the 1st time. pulled in the 8,000 lb class   ended up in middle of the pack.20/21 tractors. our 185 is out of the field stock. pulled against some 4010's with turbos a hot rodded ford& turbo'd 686 ih. pulled against a turbo'd 180 that had me bye only 7-8 feet. I pulled in 1st high (big mistake should've used 2nd low) tractor bit real nice front tires slightly lifted at the 170ft mark and she bit and hung in there til spinning out at196.7. felt like it has good leverage and is balanced pretty good.the motor didn't even pull down any til I mashed on the brakes at the end. I had to remove 2 cab doors to get it right at 8,000. pete
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 6:29am
Your spinning out was not a big mistake by using high 1st. Everytime you pull, you'll learn something. Bet you had a good time and are ready to do it again !
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 7:37am
yeah I'm pumped for sure. next pull I'm gonna raise the hitch 1/2" and pull in 2nd low and see what happens. wanna get a good baseline before adding a turbo.i wanna give the green& reds something to look over their shoulder about.
Edited by studer automotive - 21 Sep 2013 at 7:38am
99 f-250 7.3 4x4
This page was generated in 0.058 seconds.
