WD Hole Digger
sjerden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Topic: WD Hole Digger
    Posted: 05 Feb 2010 at 9:50pm
I just purchased a post hole digger for my WD. Does anyone know what weight oil I should use to fill the gear box?
PennsylvaniaNewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PennsylvaniaNewt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 12:24am
Nice
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 1:59am
I have no idea what oil to use but nice post hole digger!
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 6:19am
80w90 or about anything slick will work fine. I had never seen one of those up close. Looks good.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 8:17am
I would guess to say 80-90wt. We use the same wt in our larger auger gear boxes at work.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 9:26am
Thank's for the information. That one's not mine. Mine is covered with a little rust, is working but in pieces right now. Here's a shot of my WD with my Case grain binder. There is a McCormick Deering corn binder in the background.
Edited by sjerden - 06 Feb 2010 at 9:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 9:40am
Nice pics. Keep them coming!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 9:45am
Nice looking Wd you have there! Here is a shot of my two row corn binder behind one of my WD45's.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 11:03am
 Used 90wt in mine & it still kept the auger lubricated...Harvey
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 11:09am
Harvey, You may need to put a seal and a bearing or two in and slow down that over lubricating of the auger. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 11:24am
 Don, I sold it at a Consignment Sale last year for $30.oo Hope to run onto an AC sometime. Nice Binder but I like the single row next to it, less work, is that a #7 or #10? A WD-45 & a #7 make a good combination...Harvey
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 11:30am
Well that's a good way to fix it too. lol That one row corn picker is a NI # 10, It will pick corn just as good as the day she was new. I love picking corn, Just hate shoving it. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 5:28pm
Here's another shot of my collection of antique farm equipment. Anything on steel, basically steam-era equipment. I think its a #10 left hand cut.
Edited by sjerden - 06 Feb 2010 at 6:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 6:09pm
Trying to keep it Allis. My WD with my two 10' Allis Chalmers discs. I was replacing the wheel bearings last summer.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 8:55am
I have one with the same gearbox but the mount for the tractor slips over the lift arms like a wd farm crane. Mine doesn't have a plug for adding oil so I lay it flat, take the plate off of the back and fill it half full of 90wt. The bottom seal used to leak so I filled it with grease. Guess what. It lasted about 40 holes before I got the privelege of fixing the bearing and the seal. Nice unit though.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 11:42am
I know where one of those post hole augers are.  Do you guys think it will be a good candidate for mounting on a Pin Hitch CA?  I know I will have to make/modify the arms on it.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 12:44pm
I  have one that fits on my d-15 series 2 i could part with .. 200 dollars
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 5:30pm
Here's the real thing. It my understanding that Allis didn't make a post holer for the WD, these were manufactured by a third party.
I don't think the angle iron welded across the two legs is original. I'm thinking about cutting it off. What is the handle that runs to the back of the seat for; is it forward and reverse, or an on and off switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 5:47pm
Handle is to set the vertical as it starts in the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 5:59pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 6:02pm
mine was made i believe by roper .. eye fits into housing down below , and with the snap couplers makes a nice digger ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 11:59am
Mine says Precision Research Development
Probably just a huge machine shop that fabricated these
