D 21 Puller For Sale
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: D 21 Puller For Sale
    Posted: 05 Sep 2013 at 11:39pm
https://www.facebook.com/video/embed?video_id=554946941231923
Tractor is a 1964 Allis Chalmers D21 Serial #1514 Tractor weights 7610 Empty. Pull in the 8500 Lb class. Motor is a 7080 engine with copper head gasket. Pump is a Bosch 10 mm at 400 cc. .093 S.S. lines and 4x.022 injectors. Turbo is a 3LM with 2.5 intake. Steel flywheel 3 disc clutch built by Kennys in Kentucky. Pulls 7th gear at 17 mph. Tractor had 400 hrs on engine when did this puller and now has 6 passes on it. Figure right at 500 HP range. Tractor was built to pull, but EVERTHING is bolted on to make back into stock someday the way these tractors are going up in value. Paint is PPG Omni. Every nut and bolt gone through. Can send a ton of photos. $25,000. Located in Lynden WA. Can arrange shipping.
Call Darryl at 360 393 7760 cell or dckrause21@hotmail.com
Thanks
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2013 at 11:39pm
Tractor SOLD Went to IOWA. Thanks
This page was generated in 0.058 seconds.
