Timing, marks use F25 degree or otherline on fly |
boscoe
Topic: Timing, marks use F25 degree or otherline on flyPosted: 04 Feb 2010 at 10:51pm |
My flywheel has a line marked on it ,also a line with the letter F and 25 degree sign. Which do you use to time engine, what is each line for? Which is TDC? It is on a D17 1959 model thanks.
DrAllis
Posted: 04 Feb 2010 at 10:54pm |
Wide open throttle time at the "F-25" mark with a timing light.
boscoe
Posted: 04 Feb 2010 at 11:05pm |
I had it running well and it wont start at all, power to everything, coil, points, gets gas. So with engine off do I start at the one other line which is TDC? #1cyl pressure pushing out finger, line is in sight hole ,line up rotor with #1 rotor post , tighten back down, points about ready to open,should start ?. I have a spray coupe with a volkswagon engine and if the points arent exact it WILL NOT RUN AT ALL. Maybe these tractors are point sensative? what am I doing wrong?
DrAllis
Posted: 04 Feb 2010 at 11:09pm |
The blank "line" is TDC..........F-25 is 25 degrees before TDC. Points to be set at .020".
boscoe
Posted: 04 Feb 2010 at 11:12pm |
Thank you Doc.
boscoe
Posted: 05 Feb 2010 at 3:29pm |
I got it running again today, I re-timed it and it started but kinda rough so I loosened the dist while running and turned counter clockwise and it now literally purrrs, It sounds great. I hope that doesnt hurt it to adjust when running.
