Installed a hydraulic Joystick
WayneinNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WayneinNE Quote  Post ReplyReply Direct Link To This Post Topic: Installed a hydraulic Joystick
    Posted: 04 Feb 2010 at 10:01am
Wanting to install a hydraulic joystick on a 200 allis.  Any options other that going out a remote on the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 10:07am
It seems I saw pictures of this done on the old site a while back. I believe they tapped in ahead of the remotes and used some kind of priority divider(improper terminology). Somebody will remember and follow up with a reply.
JR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 4:59pm
I just put 1 on my 170. Mine had a rubber hose about 18" long in the pressure line coming from the pump. I removed it and put the side coming from the pump on the "in" side of the joystick and ran the "out" side back to the line going to the valve stack on the tractor. It really does not matter where you break into it so long as you put it in series since you have open center system. Just remember which ever valve is first in the series will have priority. You also need to make sure you have an open center valve. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:59pm
You must have an "open center" valve with "power beyond" capabilities, which has an "in" port and an "out" port and a bleed line that goes back to sump. Failure to have this type of valve can explode it when using the tractors regular hydraulic valves under pressure.
JR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:33pm
Exactly how will it explode the tractors regular valves if it is in series with it? We have done it that way for years on machines in the factory don't know of any problems. But I guess if you put it before the relief it could be a problem. Mine is before and works fine.
This page was generated in 0.332 seconds.
