D 12
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Topic: D 12
    Posted: 04 Feb 2010 at 6:11am
Why wouldn't a D 12 III have a traction booster gauge on it?  It has a factory
plate.  Thanks!
Ed
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:52am
According to my service manual, some D10/D12s did not have a TB setup, especially those with the 3PTH and/or those with the engine mounted hyd pump.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 10:10am
I thought by Series III all D10/12 had the independent hydraulic pumps at the rear of the tractor and draft-sensitive hydraulics even with the 3-point hitch?  The 3-point used some kind of torque bars for draft sensing.
Earlier versions of the 3-point with the engine mounted hydraulic pump were not draft-sensitive.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 1:01pm
Traction booster gauges were not the most dependable and many times removed.  Some tractors came with the traction booster system, just not the gauges, especially the small ones.  Their really not that useful anyway, you can feel/hear the tractor labor and set depth lever to were it works the best by feel.  Reproduction gauges are non functioning as far as I know.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 1:21pm
  we carry working gauges   1-800-254-3116
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 6:57pm
According to some sales literature I have on the D-10 / 12 Series III, on the high clearance (hi crop) versions, they did not have the traction booster.
TerryMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 8:16pm
My standard D12 III has draft control but no traction booster gauge. It has the plate also. My D-10 III is the same.
This page was generated in 0.176 seconds.
