smaller front tires
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: smaller front tires
    Posted: 03 Feb 2010 at 10:56pm
i was wondering about using the small temporary tires found in cars on the front of wd45  for pulllin. i would get the benifit of less weight in those tirse plus the advantage of them being smaller in diameter. having them being smaller in diameter would set the front lower making the front harder to raise.. would i be right in this thinking? would these tires fit?
thanks in advance
if farming was easy everybody would be doing it
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:54am
Totaly a matter of opinion and im sure everbody has there own theroy. With the front end lower it makes your drawbar head up hill instead of level. My opinion is I would rather have drawbar level. Heading uphill makes ur center of pull on drawbar lower than the actual hook point. And with drawbar heading uphill seems to pull front end faster. there for looseing hook height sooner. Where as a leverl drawbar u actualy start with a higher center point on the drawbar. Totaly my opinion im sure this debate can go on forever.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 2:07am
Smaller tires on the front will help you in pulling. The lower the front end is that much farther it has to pull your front end up. I havent seen any car tire that will bolt up due to the size of the center hub, however a 5 lug farmall ( i know its like cussin to metion that name here) cub rim will fit they usually run 4.00-12 tires. They are quite a bit shorter than the 5.50-16s your tractor came with
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 6:56am
the Temp spare from a early 90 S10 blazer will fit . I put one on mine to get it back to the shop. it should be a unaversial spare with a large center hole and double drilled for 2 differant size 5 bolt patternes
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 7:25am
i have some rc rims for sale with 15 inch new tires, will bolt right on,
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 9:19am
Our nephew put a D17 narrow front under a D21 years a go and used the tem. rims and wheels for a while till he drop it to hard and bent the rims think they were chevy or pontiac Niel
