WD 45 vs D17
WCinVA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCinVA Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 vs D17
    Posted: 27 Aug 2013 at 8:21pm
What is the difference in a WD 45 engine compared to a D17? And which block would be better to start with in a WC project?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 8:31pm
Main bearings are heavier and I believe there is some reinforcement in the block webbing. If your club will allow, go with the 17 block.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 8:32pm
the later 17 or e gleaner has a better oiling system that's why i used the e engine
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 8:36pm
 D17  head breathes better, better oiling, Beefier crank  with center thrust bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCinVA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 8:42pm
Thanks for the info guys. Sounds like I will go with the 17.
This page was generated in 0.115 seconds.
