78 air planter |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Topic: 78 air planterPosted: 03 Feb 2010 at 4:21pm |
Is there a cheaper source for the foam cut off seed pads other than the $44 each at AGCO? Looks like $90 per row! Looking at a 333 air planter this weekend. Thanks. Lonn
Wink I am a Russian Bot |
michaelwis
Posted: 03 Feb 2010 at 8:15pm |
lonn . did u get that planter ? was it a 6 row ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Lonn
Posted: 04 Feb 2010 at 5:23am |
No money exchange yet but going to look at it maybe Saturday if weather permits. Yes it's a 6 row 30 in. Never owned an Allis planter before. Have a Deere 7000 4RW right now and it has seen it's better days and since I picked up an M2 with 6x30 corn head I need to make a switch and with only 83 tillable acres I thought the high priced Deere and White planters were too much. Do you know much about 78 air planters Michael?
michaelwis
Posted: 04 Feb 2010 at 6:07am |
back in the early 80,s we demo,d an ac air no till planter .. it usesd seed disks ....it put the seed in the ground exeptional .. but dad got a better deal on a ih cyclo . go figure .. piece of junk .. which got traded for a 7200 jd really liked that planter . should have kept it ..
Lonn
Posted: 04 Feb 2010 at 6:09am |
I see you're looking for a planter too.
DrAllis
Posted: 04 Feb 2010 at 6:15am |
Buy only the LONG seed pads.....short ones are not needed.
michaelwis
Posted: 04 Feb 2010 at 6:17am |
LONN ,,YES I AM .. good ones r hard to find
Lonn
Posted: 04 Feb 2010 at 7:44am |
Thanks DrAllis, apparently no aftermarket?
Michael, I can't find many in upper midwest but there seem to be a lot more straight to the south. Quite a ways away though.
Wade (IA)
Joined: 12 Sep 2009 Location: Osceola, IA Points: 232 |
Posted: 04 Feb 2010 at 8:01am |
Michael, are you looking for a wide or narrow row planter?
Kevin(Alabama)
Joined: 12 Sep 2009 Location: N.W. Ala. Points: 578 |
Posted: 04 Feb 2010 at 8:24am |
I ran a 12 row 30 with 78 air units. It was a good planter but for no-till the coulter springs are rubber and had trouble with them braking. If you could find a Deutz Allis 385 you would have a much better planter for the same money. But you still have the same coulter springs but could easily replace them with a yetter or other coulter. But in your area the coulters would not take the abuse that they take here either, but this problem is with no-till only.
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
michaelwis
Posted: 04 Feb 2010 at 4:34pm |
QUOTE=Wade (IA)]Michael, are you looking for a wide or narrow row planter?[/QUOTE]
6 row narrow
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 04 Feb 2010 at 8:32pm |
kevin, alabama, Did the Deutz 385 ever come in a 12 row, 36 inch configuration? If they did, where could I find one? Darrel in ND
Kevin(Alabama)
Posted: 05 Feb 2010 at 2:09am |
I'm not sure darrel, I will look in my manuel and see. I would think you could make a 10 row 36 out of a 12 row 30. I will get back with you.
