8070 FWA front tire and rims swap?
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: 8070 FWA front tire and rims swap?
    Posted: 03 Feb 2010 at 12:18pm
My new to me 8070 FWA is sitting on 18.4x26 front tires - Firestone radials - I'd call them 90%.
I will be using this tractor as a planting tractor and would prefer 14.9x28s instead.
Anybody up for a swap of rims and tires?
Or will sell outright.
Central Iowa.
PM me if interested.
Thanks.
JimNEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimNEIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 6:09pm
Won't that mess the front to rear ratio up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimNEIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 6:33pm
Just noticed you said 28's.They probably would be the same height.
Eric NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:01pm
The 14.9 width would be ideal for planting, but you would need to install 14.9R30's in order to maintain the correct rolling circumference as your 18.4R26's. You can check the specs at: http://www.firestoneag.com/tirelist_pop.asp?ref=3&load=0 Eric NY
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 9:43pm
14.9 28's are the correct front tire to go with 20.8 38 rear
