D19 diesel value
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Topic: D19 diesel value
    Posted: 03 Feb 2010 at 10:02am
Looked at some WDs and WCs for sale last night. I bought a WD with wide front, no engine, junk tires and wheels. The guy also has a D19 diesel that he's not sure if he's going to sell yet or not. It's a diesel with wide front and non-power adjust rear wheels and snap coupler. Lots of grime on the engine. Flat tire on the rear. grill mangled. no turbo charger, just a straight pipe on top of the manifold. He said it does run but smokes A LOT and needs to be rebuilt. Paint poor. He was thinking in the $2500 range but wasn't sure. I didn't make an offer but was thinking more like $1250-$1500. I'm thinking there's about $2000-$3000 in parts and repair to fix it up to a use able farm tractor. This is in central Wisconsin area. Anyone have thoughts on it's value?< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 10:12am
If it smokes a lot under load, it might be because the turbo is removed and they are still pumping the same amount of fuel with not enough air to burn it all.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 10:53am
I'd say your numbers are closer....
ALLIS EXPRESS!
This year:
