AC D-21 8000 lb class
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: AC D-21 8000 lb class
    Posted: 18 Aug 2013 at 1:19pm
Sam Good winning the 8000 farm stock class
[TUBE]http://youtu.be/eLP18GyagsA[/TUBE]
Charlie
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2013 at 1:29pm
great video thanks for sharing
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2013 at 2:11pm
that looks farm stock.....not
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2013 at 3:14pm
8000 lb????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2013 at 4:10pm
yes, 8,000 lb class.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2013 at 4:56pm
Never seen a d21 get that light around here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2013 at 5:49pm
Sammy Boy had the gear and the front end weight figured out just right.
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 8:18pm
my d21 weighs 7530 lbs with me on it and i weigh 215 lbs. we pull in the local farm pulls in their 8 mph modified class. if i take off my center weight racks and 2 outer deck plates it gets down to 7490
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 8:54pm
Dang! My 190xt weighs about 7300 with me (200 lbs) and that is with no pto housing, a 200 front bolster, cut off front axle knees and only one battery. Most d21s here pull in the 10500 class. Although most are series II. Are the early ones lighter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 9:05pm
mine has no pto ,pressed steel wheels with 20.8 x38 tires and the frame off the old "dennis the menace" d21 a d17 wide front weldedon it. also no 3 point and factory fuel tank removed and replaced with a 5 gallon aluminum fuel tank. it's no beauty but it's very competitive around here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2013 at 7:03am
A few older items I had on file for Sam's D21
Last years fair pull
[TUBE]http://youtu.be/VDKsQhtFi8Q[/TUBE]
[TUBE]http://youtu.be/CMsHMS3sgcw[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2013 at 8:46am
Nice tractor
