High Compression WC/WD piston
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Topic: High Compression WC/WD piston
    Posted: 02 Feb 2010 at 2:53pm
 Looks like I got a set of used high compression pistons. Book says 6.6:1 compression, part number 224754 piston blank 224753 stamped on piston. Flat top's I'm measuring about 2-1/2 compression height. Should give over 10:1 compression with 45 crankshaft. Might be for sale I just grabbed one out of the shed to measure and it looks real nice. I'll have to check the other (3) when I go up to the farm next week.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 2:58pm
what size bore? 4" or 4 1/8" ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 3:36pm
 Theses are OEM A-C 4.000" bore high altitude pistons. Pistons should hit the valves with the 45 crankshaft.
