H-3 Locks for Idler Adjusting Screw |
orangeman
Topic: H-3 Locks for Idler Adjusting ScrewPosted: 13 Aug 2013 at 5:41pm |
Anyone on here parting an H-3? I am in need of two locks for the Idler adjusting screw.
These would be for the early design which carried the 1.250" B-7 threaded adjuster. They could be machined but likely cost prohibitive. Please send a PM with price and availability. Thank-you...Orangeman
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 13 Aug 2013 at 8:17pm |
CAN YOU POST A PIC OF WHAT YOU NEED? OLD ONE OR LOCATION SHOT ?
tom38
Posted: 23 Aug 2013 at 8:49pm |
could anyone tell me if any other radiator will interchange with a H3 gas, or does anyone have a radiator & how much. thanks a lot. tomkat
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 23 Aug 2013 at 9:12pm |
I would hazard a guess, that a d-15, or d-15II radiator would fit. measure the distance between the 2 bottom mounting holes, and I'll see if it matches my d-15II.
tom38
Posted: 23 Aug 2013 at 10:20pm |
hi, my bottom holes are the same as the top ones & they are 19 inches from side to side. the radiator is 21inches tall with the top water port is in the middle & the bottom one is on the left. thanks tom
DiyDave
Posted: 24 Aug 2013 at 5:21am |
Bottom holes I am referring to are the 2 tabs, that stick out, bottom, forward of the radiator, 1/2" holes, I think. I'll try to measure the old radiator out of my D-15-II, when I go get the tractor to cut hay today. Otherwise sounds like the same radiator.
Edited by DiyDave - 24 Aug 2013 at 5:22am |
DiyDave
Posted: 25 Aug 2013 at 6:29pm |
My radiator off the D-15II is a tad taller, I think, than your H3, tab holes are about 13-1/2" OC apart. Double check the height measurement, from the cap gasket surface to the bottom of the radiator.
tom38
Posted: 25 Aug 2013 at 8:40pm |
diydave my bottom tabs are 13-1/2" apart & the height from the top of the filler neck to bottom of the bottom tabs is 23-3/8", I also noticed on the top tank in yellow crayon like from a junk yard,is AC D14.also on my rad. the side tabs as I call them are 6-1/4"apat & they are 3-1/4" up form the bottom of the rad. these are threaded nuts which are 5/16x18thread &these are what attaches the rad. to the 1/4"plate that goes around the rad.from one side around the front to the other side & is about 25" tall & attaches to the frame of the dozer.
DiyDave
Posted: 26 Aug 2013 at 5:32am |
Sounds like you found what to look for radiator wise.
