Anybody else have a decal like this?
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: Anybody else have a decal like this?
    Posted: 01 Feb 2010 at 8:19pm
This decal is on my early One-Ninety was wondering if anybody esle has this decal on theirs that is in better shape.  Looks like it says something about adding extra weight to the tractor to ultilize the engines power.  Does anybody offer a reproduction or have a picture of a good one to see what it all says for sure?  Thanks for any help.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 9:24pm
Oldoug, I am guessing at what it says....believe it might read:
To get the maximum use from your One-Ninety tractor, it will be necessary in some conditions to add extra weight to be able to utilize the engine's available HP. For 1, 2 and 3 speed operation, the tractor's max weight should not exceed 11,250 lbs.
Really guessing at the 1st line! Thanks for the challenge!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 10:19pm
Agree with all but the first line.Too much space for the words you guessed.I have no idea myself.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 10:23pm
how about"...maximum performance from..."????
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 10:24pm
I think you got it
If fishing is a sport your looking at an athlete
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 10:25pm
A friends Case IH says something along those lines in his owners manual, it reads "to get maximum fuel economy from" because at such slow speeds you need more weight to prevent slip but at high speeds the weight just puts more load on the tractor. I am not saying thats what this sticker says but it is an idea
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 11:01pm
The top line could also be (To get the maximum traction from your One-ninety)
   The line (to b"e able to u"tilize the engines) is to long to fit in that space. My guess is (to better utilize)
If you can get me the measurements of the decal and the letter size, I can dupllicate it for you. I have a sign shop and run a digital printer/plotter and a vinyl plotter.
Edited by split51 - 01 Feb 2010 at 11:09pm
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 11:48pm
Would it have said "NOTICE" above the note? Seems like there's alot of room there.
mojo/Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 12:01am
Mojo, My guess would be no. Other than the small "printed in the USA", there is an equal amount of blank space on the bottom as the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 12:35am
I buy "PERFORMANCE ".It makes sence too!
