2900 Series Question
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Topic: 2900 Series Question
    Posted: 01 Feb 2010 at 12:28pm
Would a 2900 series motor from an L2 bolt into an XT? Got an XT and need a motor
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 2:58pm
yes but you will need the tractors engine rear plate. there might be a few other modifications but thats the main on that i know of.
hope this helps
ryan
Edited by ryan(IN) - 01 Feb 2010 at 2:59pm
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 6:37pm
front covers will need to be swapped as well - the biggest problem is the front axle will hit the larger oil pan on the XT - Either find a 200  front hsg or cut and reweld the pivot pin on the axle about 3.5" higher (or whatever the bolt hole distance is on the rear axle support) and add a plate on top of the rear axle support drilling it to fit the holes as the top set will now become the bottom set.
The fan location on some L's will be different and the shroud will have to be modified. Keep the electric fuel shut off - it is neater.
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 6:40pm
You will also need to swap the front cover and if I remember right the cylinder head is different, I swapped one into 7000 a few years ago and i beleive it was a water port that was different, so i swapped the head.
andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 6:42pm
Is there also such thing as a Mark II 2900? I was told the one in the L2 is a Mark II but wasnt sure of that.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 7:24pm
  we have  a 2900 engine in a tractor   northern ind.  1-800- 254- 3116   call for more info.
