dozer blade cutting edge
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: dozer blade cutting edge
    Posted: 05 Aug 2013 at 9:15pm
Anybody got any ideas where to get aftermarket replacement cutting edge for a off brand [Dresser] dozer blade? Broke one of the sections on mine today, thought I would look elsewhere before I called Dresser.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 9:43pm
Broke a piece out of the cutting edge on my Dresser today, was wondering if anyone knew of a place to get an aftermarket one.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 10:51pm
Any supply house for steel should be able to get you one .
depending on the punching many units are interchangeable as punching can be standard.  Look up online for cutting edges - or heavy equipment repair and they can also direct you to some place locally for you
Andrew_D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2013 at 6:17am
Well, "here" I'd check with CAT first. Even the local municipalities with Deere graders buy their cutting edges at CAT - much cheaper.
Just bought some for our farm tractor (14' blade - 2x7' edges) from CAT. Phoned them with the length, thickness, bolt spacing, bolt size and the parts guy immediately knew which edge it was. CAT came in at $440 for the 2 edges and all the bolts. Dealer was just shy of $750.
Andrew
Edited by Andrew_D - 06 Aug 2013 at 6:18am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2013 at 2:06pm
this is what i did. much cheaper for someone not making a living on their old machine.
cutting bit fix
on second thought, if your using your machine hard enough to break the OE bit, I would buy a new one also.
Edited by CAL(KS) - 07 Aug 2013 at 2:09pm
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2013 at 4:57pm
Cal(KS)  I've been through replacing cutting edges on our FA 10.  Needed a new cutting edge as both sides had been well used.  With a Fiat the warning was "Is it 6" bolt spacing or 150mm, as they're NOT the same".
Ours was 6".  Probably as a result of a deal with lower import duty if locally manufactured items such as blades were added.  So I could use standard cutting edge plates from a Komatterpiller dealer
End bits were not readily available obtainable but I was pointed to "End bit repair sections" (also known here as hockey sticks) in a range of sizes pre-formed to the shape of the lower side of the end bit.  You work out which ones have enough material for your job, then you trim and weld on to replace the worn areas.
I'll post some photos, but not this day.
This page was generated in 0.490 seconds.
