7000 Front Axle
JR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Front Axle
    Posted: 01 Feb 2010 at 11:00am
I a 7000 Red Belly That I can't seem to keep the front tires tight on. I re torque all the time they still come loose (no loader). Does anyone know if anything can be done? Or how hard would it be to change it out to the HD 8-lug hubs or axle?
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 4:29pm
got a hd front axel from a 7000 il sell buildin a puller dont need it  217 -712-0984
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 7:37pm
It's not too hard to do either. It sounds like the threads on the wheel bolts or hubs or both are worn. I have a complete axle for $500.00 with tires. Or use lock-tite.
Dan (SE MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan (SE MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 9:39am
We had a similar problem once.  We ended up using longer bolts that threaded through the hub and then put a jam nut on the back side of the hub.  It fixed the problem, but the permanent solution was to replace the hub.
-Dan
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 11:01am
You can also screw bolts through the hub from the backside that are long enough to act like wheel studs and then use lug nuts on the front side. This is how I put chrome lug nuts on some of my tractors. Kip
